New Features of RiskyProject 4.2
RiskyProject Professional:
Advanced Project
Risk Analysis
RiskyProject Lite:
Introduction to Project Risk Analysis
Here are some of RiskyProject clients:
Improved qualitative risk analysis and risk management:
- A new Risk Form helps you to enter main risk properties: risk cost, ownership, planning strategy, risk timeline and other information;
- An improved Risk assignment interface makes it easier to enter risk probabilities and outcomes and assign your risks to a project's tasks and resources;
- An improved Risk Mitigation workflow helps to assign mitigation plans to different risks;
- If a schedule is not part of the project, RiskyProject performs qualitative risk analysis; if project schedule is available the same Risk Register can be used for quantitative risks analysis through assigning risks to tasks and resources
- Risk life cycle: convert risk to issue and lesson learned
Improved risk matrix for qualitative and quantitative risk analysis:
For qualitative analysis, you can now customize the text labels for risk outcomes that will guide your users. For example, for safety risks, you can provide additional text such as "Serious - hospitalization required"
Fully customized detailed report for each risk.
Risk history (all changes to risk properties) and risk view data.
Risk Matrix.
The Risk matrix shows project risks' impact and probabilities and allows you to identify critical risks. In addition, the Risk matrix shows both threats and opportunities. The Risk Matrix is fully customizable: you can define the size of the matrix and risk attitude.
Cost of risk calculation: potential loss, cost of mitigation efforts, savings from mitigation efforts.
Uncertainties in risk outcomescan be used for qualitative and quantitative analysis. For example, risk may cause delay between 10 days and 20 days defined as an uniform statistical distribution.
Improved user interface and Monte Carlo simulation performance; new ribbon interface has been introduced; assigning low and high estimates for duration and cost for a group of tasks has been improved;
RiskyProject is now seamlessly integrated with Microsoft Project 2010 using RiskyProject ribbon in the Project. You may map fields in Microsoft Project to parameters in RiskyProject. For example, duration1 in Microsoft Project could be imported to Low duration in RiskyProject. RiskyProject is also integrated with Oracle® Primavera, Safran, and other project management software.
RiskyProject can now import probabilities and outcomes of risks from Microsoft Excel.
RiskyProject 4.2 can be installed together with previous versions of RiskyProject (uninstall does not required). All current users of RiskyProject 3.x can upgrade the software free of charge. If you are the user of RiskyProject 2.x please contact Intaver Institute for the upgrade.
