Assigning resources to tasks
1. On the Workflow bar, click the Gantt
View.
2. Select the task to which you want to assign the resource.
3. Click in the Resource field associated with the
task.
4. Select a resource from the drop-down list. If you type in a new
resource name, it will be added to the list of resources in the
resource view. When you add a new resource in this manner, it will
be assigned at 100% effort for work resource.
To
assign resources at less than 100% or if want to assign material
resource, you must go to the Resources tab in the Task Information
dialog box.
Multiple resources can be assigned to a particular task.
• Tasks do not have to have resources assigned to them.
Managing Resources and Work
Resource calendars
Defining work for task types
