           Task Related Fields
                 Total Task Cost Low - result
                 Name of parameters (shown on the tool tip)  |
                             Total Task Cost Low - result (min, P1,
                             P5,
                             or     P10)
                 Type of the field  |
                  Static Text  |
                 Short name (shown in the
                header)  |
                Cost
                Low
                 Description  |
                         Total low cost (fixed task cost plus
                  variable cost, e.g. associated with resource) as a result of
                  probabilistic calculation.
                         Will have no value in
                  the current schedule calculation. Can be minimum,
                         P1, P5, P10. It is defined in Options
                  (Calculation tab).
                 Related
                Fields  |
                    Total Task Cost
                  Base  Total Task Cost High- result Total Task Cost Mean
                  - result
