Once you have added your risks you can start assigning your local
risks to tasks and resources. You cannot assign the same local risk
to both a task and a resource. RiskyProject offers a number of ways
how risks can be assigned to task and resources.
Method 1: Assigning global and local
risks using risk register
This is a preferred method for assigning risk in complex project.
This method is also useful when you edit risk assignment, for
example for mitigation planning. You will be able to view all risk
assignments in one place. With the risk register, you can assign
both local and global risks.
Method 2: Assigning local risks using
the Global Risk Assignment view
This is a preferred method for global risk assignment. You may use
this method for assigning local risks based on global risks. If you
have global risks, you may assign it to one of many task and
resources at the same time.
Method 3: Assigning Local Risks using the Local Risk Views
You can define local risks using the Local Risk Assignment (Tasks)
or Local Risks Assignment (Resources) Views. This is the preferred
method when you have risks with the same chance of occurrence,
outcome, result and moment of risk assigned to many tasks.
By default, this view is not shown in the Risk workflow bar. You can
open this view by clicking the All Views button in the Workflow bar
and selecting Local Risks (Tasks).
Method 4: Assigning Local Risks Using the Task Information
dialog box and Resource Information Dialog Box
You can define task risks in the Risk Tab of Task Information or
Resource Information dialog boxes. All risks entered here are “local risks” and will not appear in
the Global Risk Assignment view. It is a preferred method if you
want to assign few different risks to few separate tasks and
resources.
Risk Register
Risk Assignments on the Gantt Chart
