Home   Online store   Demo   Forum   Site Map
Project Risk Management
Project Risk Management Workflow
The RiskyProject workflow includes four major steps, as shown on the diagram. Each step includes a number of activities and each activity is associated with at least one RiskyProject view.
The four major steps of the RiskyProject workflow are:
1)       Create a baseline (original) project schedule, which includes risks and uncertainties;
2)       Perform simulations,
3)       Analyze results, and
4)       Track project performance.
During the course of the project, actual performance is monitored and tracking information is updated. All process can be repeated again as soon as new data about project performance become available.
RiskyProject allows you to compare baseline schedule with the calculated schedule that takes into account risks, uncertainties and actual project performance.
At any step in the workflow, the data and simulation results can be viewed in several different formats.
1. Create Baseline Project Schedule
In this step, the project schedule is defined along with uncertainties, resources, and risks.
Project Schedule
Task scheduling in RiskyProject is very similar to the process project managers use with traditional scheduling software and methodologies. The project schedule is based on tasks and is presented as a Gantt chart. The project manager specifies input project parameters, such as: duration, start and finish time, cost, etc., that are associated with a “best case scenario” outcome. You can use project schedule created in Microsoft® Project, Primavera®, or other project management for the risk analysis in RiskyProject.
Gantt Chart
Click to enlarge
Resources and Costs
Project managers can then define work or material resources and assign them to tasks. There are two types of costs in RiskyProject: Fixed costs, which are associated with tasks, and variable costs, which are associated with resources. Costs associated with resources are calculated based on rate, units assigned, and task duration.
Project Resources
Click to enlarge
Risk Breakdown Structure
Creating a Risk List is an important step in RiskyProject. Risks can be assigned to a task or a resource. The Risk List can be local  (for each task or resource), or global (for all tasks and resource in the project). Each risk has a number of properties. Risks are defined by name, chance of occurrence, and outcome (e.g. increase cost, cancel project, etc.). Risks can also be defined by when they are most likely to occur using distribution types and the entering the points, as a percentage of task completion, when the risk starts and finishes.
RiskyProject allows you to define uncertainties and task duration, cost, start and finish times, as well as lag time between predecessors and successor using statistical distribution. To add uncertainties you enter low, base, and high estimates for a variable (e.g. duration). You can assign Uniform, Triangular, Normal, Lognormal, Beta, BetaPert, Gamma, and other distributions to this variable.
Project Risks
Click to enlarge
2. Simulation and Data Analysis
You can now calculate the project. To calculate the project, click the Calculate button (for small projects calculations are done automatically) and Monte Carlo simulations are performed. RiskyProject offers a number of tools with which you can analyze the results.
Project Summary
The Project Summary provides two different types of information. At the top, you can quickly view general information about the project, name, manager, description etc. The bottom section shows the results of the calculations without taking into account the project baseline. This information includes ranges for the project:
·         cost,
·         duration, and
·         project finish time.
Interactive charts are also provided, which allow you to determine the chance the project will be completed on certain date, will have a certain duration, and will have a certain final cost. The project Summary also provides the overall project success rate, or chance that project will be not canceled.
Project Dashboard
Click to enlarge
Result Gantt
The Result Gantt chart provides an easy way to view the low and high ranges for start and finish dates for each task. It also allows you to view the baseline and calculated project schedules side by side. This allows you to quickly determine how uncertainties affect each particular task.
This is also an opportunity to perform a reality check. With the Result Gantt chart, you can easily see how the project schedule slips due to uncertainties and determine whether your initial estimates for the project and the risks and uncertainties were correct.
Result Gantt Chart
Click to enlarge
Sensitivity Analysis
Sensitivity analysis determines which variables have the most potential to affect your project. These variables are:
·         task duration,   task start time, success rate and costs
·         risks
·         lags between predecessors and successors
You can check how these variables affect the main project outcomes:
·         total project cost
·         project duration
·         project success rate
The sensitivity chart displays sensitivities in descending order: variables whose uncertainties affect the project schedule the most will are placed at the top.
Tornado Diagram
Click to enlarge
Crucial Tasks
The Crucial Tasks chart shows the results of the sensitivity analysis on a Gantt chart. Uncertainties whose duration has the most affect upon the total project duration are crucial tasks and are shown in red. By mitigating risks associated with crucial tasks, you can significantly improve your project’s chance of success.
Crucial Tasks
Click to enlarge
Success Rate
Risky Project calculates every task’s success rate or chance of completion. The results are shown on the Success Rate Gantt chart using different colors. Tasks with high success rates are green, medium success rates are yellow, and low success rates are red. You can cancel tasks, if a risk with “Cancel Task” outcome occurs, or if a task has reached a project or task deadline.
Success Rate
Click to enlarge
3. Tracking
Project tracking is an important step in the project management process. When you track a project that has uncertainties, you can apply newly obtained knowledge about project performance and recalculate the project so that it is an accurate reflection of the project’s progress. RiskyProject uses unique mathematical methods to calculate projected duration based on this tracking information. In addition, RiskyProject automatically updates the chances that specific task risks will occur. For example, if at the start of a task a risk has a 50% chance of occurring over the duration of the task, if the task is 50% complete, there is a reduced chance that the risk will occur.
Input Tracking Data
You can add information about each task. This is entered as the percentage of work done at a specific date. RiskyProject recalculates and shows an updated duration projection on a chart.
Project Tracking
Click to enlarge
Analyze Results with Tracking
After you add tracking data, you can recalculate your project schedule. RiskyProject applies the updated duration and chance of occurrence for risks. You can view the new project schedule on the Tracking Gantt chart. The Baseline schedule is also shown in the chart, so you can assess how your original estimates are different from actual project performance.
Project Tracking
Click to enlarge
www.intaver.com products      solutions      technology     services     support     partners     company
Legal Notice Privacy Statement Copyright © Intaver Institute Inc., 2002-2008. All Rights Reserved
