Methods for applying uncertainties
Ken
Post by Ken »
What are the options for modeling uncertainty in Risky—empirical data or uncertainty bands? Are they alternatives?
Re: Methods for applying uncertainties
Yes. Risky allows you to model uncertainty using:
  • Uncertainty bands,
  • Low/High Duration settings with statistical distributions, or
  • Manually entering low and high durations and setting the statistical distribution using the Statistical Distribution for Duration field which can be added as a column to Project View.
These approaches serve as alternative methods for defining uncertainty in activity durations.
Best Practices
  • Use empirical data when you have historical project data you trust.
  • Use uncertainty bands or distributions when data is limited or expert judgment is required.
  • Maintain consistency across tasks—avoid mixing methods arbitrarily within the same project unless justified.
  • Document your assumptions so results are defensible during reviews.
