Primavera P5/RiskyProject integration
How can I import data from Primavera P5 to RiskyProject?
George, Ph.D., PMP
In order to use RiskyProject with Primavera to need to export Primavera data to MPX or Microsoft Project XML formats. Please note, that in order to export data to Microsoft Project XML you must have MS Project installed on the same computer as Primavera. Then you can import MPX or XML file to RiskyProject. Many our clients are successfully using RiskyProject with Primavera P3, P5, and Suretrac.
You may use either MPX or XML. XML is better. It is newer format for MS Project. It contains some important information which MPX does have.
Primavera files
We have tried using mpx and xml, but have had some changes occur with activity dates etc. Is there anyway we can resolve this?
