Number of Projects in RiskyProject Enterprise
How many schedules cam I have in RiskyProject Enterprise?
Re: Number of Projects in RiskyProject Enterprise
A lot, the hard limit as defined in the software is 20,000. However, you would probably reach a “soft” limit much sooner due to limitations in network bandwidth, database performance, and desktop resources required to render such a massive portfolio.
If you use SQL Server express there is a limit of total database size. SQL Server Express does not support databases larger than 10 GB. It means that you may experience limits on documents attached to risks, as well as very large schedules.
