Risk Trend Chart Settings
Using Risk Trend Chart settings dialog you can define:
- Order of bar on Risk trend chart associated with particular risk ranges. For example, for each time period Low risks (Green color) will
first, Medium risk (Yellow color) will be second and High risks (Red color) will be third. You can use Move Up and Move down buttons to to define the order.
- Name of each range.
- Risk trend chart periodicity (Monthly, Quarterly, Yearly, etc.)
- Maximum number periods in in Risk Trend Chart. For example, Risk trend will show 10 month back starting from the current month.
Formatting Risk Matrix
