Mapping user defined fields in XER files to RiskyProject fieldsIf you are importing an Oracle Primavera *.xer file, you can use user defined fields to import low, most likely, and high estimates for duration and cost by mapping these fields to corresponding fields in RiskyProject. To map user defined fields, you would need to choose an XER file to use as a mapping template. To map user defined fields in XER:
You must use number (not text) user defined fields in Oracle Primavera to enter low, most likely duration and cost. XER File EncodingXER files do not include any information about what is being used to encode the files. If the file you are importing does not use standard encoding (for example, it uses Russian instead of English), then the characters may not display correctly when you import the file. You need to define encoding before you import XER file. To define encoding:
See also |
