Risk Status View
You can use Risk Status View as a depository of changes to risk probability and impact. It is similar to Risk
History, but contains more information, while can be edited, printed and exported to Excel. Each time risk
probability and impact are changed, the record will be added to the Risk Status view. The main purpose of
this view is to show how probability, impact, and changing over time for all risks. The record includes:
To assign a mitigation plan to a risk:
- Risk name and Risk Unique ID, associated with the record
Date of the change
Description of the change
Pre-mitigation probability, impact, and score for all categories. It can be used as predicted probability, impact, and score. They are generated automatically based on what is defined in Risk Register view, but can be modified by the user.
Actual probability, impact, and score for all categories. They are user defined in Risk Status view.
Pre-mitigation and actual probability, impact, and scores for individual categories. They are user defined in Risk Status view for each status record and may not correspond with probability, impact, and scores for individual categories in Risk Register view. Columns for this data are hidden by default.
- Additional information, which can be recorded in five custom text fields and five custom number fields for each record. Columns for additional information are hidden by default.
To enabled automatic saving of changes in risk probability and impact as Risk Status record:
- Go to Options.
Go to Risk tab.
- Select Update Risk Status when risk probability/impact are changed.
Notes
You can modify, delete, or insert Risk Status records. To delete and insert record right click on Risk Status record ID and select Delete Risk Status or New Risk Status from drop down menu.
You can import data from Excel to Risk Status view.
You cannot use this view to modify risks or insert more risks.
Probabilities, impacts and scores for individual categories are not used to calculate pre-mitigation and actual probabilities, impacts and scores for all categories, which need to entered separatelly.
Assign Mitigation View
