Professional version onlyUsing Empirical Data to Generate a Statistical DistributionYou can use empirical data to define a custom statistical distribution. The data must be saved in a comma separate file and contain numbers only. The minimum number of values should be 20. At least one value should be different from all others. If there is a text field, it will be interpreted as a zero value. Values can be entered on multiple lines. But it could be one row, or one column. Here is the example of a file: 67.78, 88.32, 32.33, 47.54, 57.32, 45.23, 58.23, 67.00, 56.20, 32.87, 32.22, 30.00, 32.33 32.99, 18.32, 56.22, 32.21, 32.98, 23.23, 73.43 58.23, 67.00, 56.20, 32.87, 32.22, 30.00, 32.33, 22.45, 48.34 Fitting a distribution:
