Adding projects from Microsoft ProjectIf you are using the RiskyProject Add-in for Microsoft Project and want to move the project data to RiskyProject Enterprise, you will be required to logon to the RiskyProject database in which you want to add the project. You can then add the project to your portfolio. You may rename or save this project to a different place at any point in the project hierarchy.
If your schedule from Microsoft Project is currently in the database, it will remain linked to your Microsoft Project file; therefore, if you make any changes to the schedule in Microsoft Project it will be reflected in the schedule within RiskyProject. See also |
