Input Distribution Chart
You can view an enlarged input distribution chart when you double-click
on the small distribution chart on the Distributions tab of Task
Information dialog box.
You can use the input distribution chart to view and enlarged probability
density function. Axis X of the function represents actual value
(duration, cost, income, or start time). Axis Y represents
probability.
Use the shortcut menu to:
- Copy chart to clipboard as metafile
- Copy
chart to clipboard as bitmap
- Copy
Chart to File (JPEG, PNG, GIF, ...)
Defining task distributions
Adding 3-point estimates
Assigning low and high duration and cost estimates to a group of tasks
