Task Sheet View
The Task Sheet view provides a table view of all the Current
Schedule's deterministic values for each task without a Gantt chart. While you
can use this view to enter or edit task data, its primary use is for providing a
table report view of task information.
Default fields
- Task Name: Name of the task.
- Base Duration:
Enter in the base estimate for the
task duration
- Low Duration:
Enter in the low estimate for the
task duration
- High Duration: Enter in the high estimate for the
task duration
- Low Start Time:Low Start Time is used for probabilistic
calculations and does not affect the current project schedule. If you modify the
Low Start Time, the Constraint is set to Must Start On". See "Start, Finish
Times, and Constraints" for more details. Particular meaning of low start time
depends on the statistical distribution for start time.
Base Start Time: is used to calculate
current project schedule. It also used to calculate start time
of each iteration of the probabilistic calculation. Note that
in most cases, the Start Time is calculated automatically
based on predecessor's finish time and lag. If a task does not
have predecessors, the default start time is the current time
or default start time from options (see "RiskyProject
calculation and display options"). If you update the Start
Time, the Constraint is set to "Must
Start On".
See "Start, Finish Times, and Constraints" for more details.
High Start Time: is used for probabilistic calculations and does
not affect the current project schedule. If you update High Start Time, the
Constraint is set to "Must Start On". See "Start, Finish Times, and Constraints"
for more details. Particular meaning of high start time depends on the
- Low Finish Time: The Finish
Time of a task
(Low) plus Duration Low that it is not result of
a probabilistic or current schedule calculation.
- Finish Time:
Base Finish Time is used to
calculate current project schedule. Note that in most cases,
Finish Time is calculated automatically
based on a task's Start Time
and duration. If you update the Finish Time, the
Constraint is set to "Must Finish On". See "Start, Finish
Times, and Constraints" for more details.).
- High Finish Time: Enter in your finish time for your
task. If you enter a finish time the cell will be
highlighted to indicate a constraint.
- Resource: Enter or select a resource to assign
it to the task.
- Predecessors: A list of predecessors for the current task. Example: 1+3day, 1SF+4day. It means: that predecessors are task 1 Finish-Start relationship with lag 3days and task 2 (Start-Finish relationship) with lag 4 days. Start-Finish is displayed as SF, Start-Start is SS, Finish-Finish is FF. Finish-Start does
Setting up reports for printing
See Setting up Reports
Printing Printing reports
Click File
and choose Print.
Previewing reports
Click File and choose Print Preview.
Setting
up your projects
