Cost and Revenue View
Use the Cost Analysis view to analyze cost and revenue on each stage of the
project.
- Tasks Name: Name of the task.
- Cost: Base fixed cost for the task.
- Cost Actual: Actual Cost can be calculated automatically
(default) using tracking data. You can manually input actual cost, if you
uncheck flag in Options dialog (cost view). Actual cash flow diagram will be
displayed within Cost Analysis view.
- Income: Base Fixed Income for the task
- Income Actual: Income that is accrued during the course of a
task or project. RiskyProject calculatea actual cost automatically based on
tracking data. Alternatively, you can enter this income manually if you uncheck
a flag in Options (cost tab)
- Res. Cost: Cost associated with all resources assigned to the
particular task. Calculated during deterministic current schedule calculation.
Resource cost for summary tasks is calculation as cost of all resources assigned
to summary task plus resource cost of all subtask.
- Total Cost: Cost associated with resources assigned to the
particular task plus fixed task cost. Calculated based on current schedule
duration and fixed cost.
- Cost: Mean Total Cost as a result of probabilistic calculation.
Will have no value in the current schedule calculation.
- Income: Total income as a result of probabilistic calculation.
- Revenue: Revenue = Income - Cost on each iteration. If Income
is zero for all tasks, revenue is not calculated. Mean Revenue is calculated as
result of statistical analysis. Will have no value in the current schedule
calculation.
The Cost Analysis view has up to three cash flow diagrams:
- Baseline (budgeted) cost or revenue:
Cash flow diagram associated with baseline project schedule (no risks).
Colour: Red, Always shown when cost or revenue for any task is defined
- Result cost: Cash flow diagram with risk and uncertainties
(calculation results). Color: Blue. Shown after calculation if uncertainties are
defined
- Actual:Cash flow diagram represents actual cost. Color:
Green. Shown after calculation if uncertainties are defined and actual cost is
available (either entered directly or percent done for at least one task is
defined)
You may use a slider with the view to determine:
- Cost Variance (actual vs budgeted
cost)
- Cost with Risks and uncertainties
vs. Baseline (budgeted) cost
Notes:
- If income is defined for
at least one task, the cashflow diagram will show the project
revenue based on the formula: Revenue = Income - Cost
- If cost exceeds Income in any given period of time Revenue will be
negative.
- If income is not defined, Cost will be always positive
Adding Fixed Costs and Income.html
