Task Related Fields
Start Time of the task (High)
Type of the field
Date Control
Start High
Description
High Start Time is used for probabilistic calculations and does not affect the current project schedule. If you update High Start Time, the Constraint is set to "Must Start On". See "Start, Finish Times, and Constraints" for more details. Particular meaning of high start time depends on the statistical distribution for start time.
Related Fields
Start Time of the task (Base)
Start Time of the task (Low)
