Risk Related Fields
Start time of the risk occurrence
Type of the field
Edit Box with Spin Control
Start
Description
Risk can only occur after this time. Time is defined as a percent of total task duration. For example, task duration is 5 days. Start time of risk occurrence 20% means that risk will occur starting second day.
Related Fields
Moment of Risk
Distribution chart
Finish time of the risk occurrence
Most likely time of the risk occurrence
