Renaming project
Posted: Sun Jun 05, 2016 2:54 pm
by NTT
How can I rename project within project hierarchy and update project parameters?
Re: Renaming project
Posted: Sun Jun 05, 2016 3:04 pm
When you create new project in RiskyProject Enterprise by using New Project menu item, you can define any name of this project. However when you already defined a project schedule for this project, you cannot rename project unless you open it. To open a project just double click on project ID. The project will become editable. You can rename project as well as change other project settings, for example project start time. If you change project start time, it will be shifted. After you close the project, the new name will be reflected in the project hierarchy, but will become read only.
