Statistical distribution for duration
Kathy
Post by Kathy »
As part of our Monte Carlo schedule risk analysis, as a first draft we are not yet requiring our team members to provide estimates for low and high duration. We want to import our schedule from Microsoft Project and quickly add uncertainties to all of the activities. I seem to remember that you can do this in RiskyProject, but I can’t find it.
Re: Statistical distribution for duration
In RiskyProject you can quickly add uncertainty to your tasks. Uncertainties are expressed as statistical distribution and will be based as an input in Monte Carlo simulation process. These statistical distributions will be used for task duration and task costs. We recommend as a first step develop levels of uncertainty each with coefficients used to calculate Low and High estimates. For example, you can If you have activities that are very routine and have very little uncertainty, they can be characterized as Very Low risk with coefficients for Low and High . 95 and 1.1 respectively.
You can do this for all your activities in Microsoft Project and when you import it into RiskyProject, this will allow you to quickly select specific risk groups to apply the uncertainty.
To apply the uncertainties to groups of activities. Select the tasks, right-click on the Task ID of one of the selected tasks and click Set Low High Duration from the shortcut menu. You can enter the coefficients you have defined as well as assign a statistical distribution type to the group.
