Default value for risk outcome
Tomico
Post by Tomico »
How can I change a default value for risk outcome? It is currently 30%. However this value should be different for different risks.
Re: Default value for risk outcome
The default value for risk outcome can be defined in Schedule -> Options -> Risk Tab. You may change this value each time you enter the risk. In RiskyProject we use default values for most of the fields to help the user to enter correct information. For example in case of risk outcomes the user will know that this value should be from 0 to 100%. Without default values the software would generate many conflicting warnings if the user does not enter something properly.
