Scatter Plot in RiskyProject
Hato
Post by Hato » Wed Aug 29, 2012 4:33 pm
Does RiskyProject generate a scatter plot, for example project duration vs. task duration or project finish time vs. task finish time?
Thanks,
Hato
Project manager
Re: Scatter Plot in RiskyProject
Post by Intaver Support » Wed Aug 29, 2012 4:45 pm
RiskyProject 5.0.3.2 has Scatter plot. The scatter plot can be accessed using Analysis tab. You may also select task, right click of task ID and select Scatter plot from drop down menu. RiskyProject has two types of scatter plots: project cost vs. task cost and project duration vs. task duration. We don't have scatter plot for finish time, work, income and other parameters.
Post by Tomico » Thu Nov 08, 2012 4:47 pm
Can I access Scatter Plol from Microsoft Project addin, the same way as I do with sensitivity chart and frequency chart?
Post by Intaver Support » Thu Nov 08, 2012 4:57 pm
You cannot access scatter plot the same way as you do with sensitivity chart and frequency chart using designated button in Microsoft Project Addin. But you may always select any RiskyProject view, for example Risk Adjusted Schedule, right click on selected task within this view and select Scatter Plot.
Post by Tomico » Sun Apr 07, 2013 6:05 pm
Is is possible to insert Scatter Plot to the report, generated in Statistics report view?
Post by Intaver Support » Sun Apr 07, 2013 6:08 pm
Statistics report may include:
- frequency chart
- cumulative probability chart
- combination of both
plus statistical tables. Although you cannot insert scatter plot to the statistics report, you may copt scatter plot to the clipboard and paste it to any report, particularly in Microsoft Office.
