Versions 2 and 1.3 together
Can I install RiskyProject Professional 2 alongside with 1.3? I don't want to remove old version before I migrate all old project.
Yes, You can install RiskyProject Professional or Lite version 2 even if you already have RiskyProject 1.3. You can open data files created by RiskyProject 1.3 in RiskyProject 2. However you cannot open RP 1.3 files in RiskyProject 2.
RiskyProject 2 will use the same license as RiskyProject 1.3. You don't need to request any special licenses.
Yes, you can have both RiskyProject 2 and RiskyProject 1.3. It will help you to make a smooth transition from RiskyProject 1.3 to RiskyProject 2. Later on you can remove RiskyProject 1.3.
You you already have a full (not trial) license of RiskyProject 1.3, RiskyProject 2 will pickup this license. You don't need to have special license key for RiskyProject 2.
No. New RiskyProject will read license information from the registry about previous version of RiskyProject. License information is not deleted when you uninstall RiskyProject.
