Setting up viewing defaults
Use the View tab to set up general project parameters and modify the appearance of the RiskyProject workspace.
- Go to File > Options.
- Click the View tab.
- Enter the default project information (i.e., Project Manager) in the text boxes. You can view them in the Project Information view n
ext time you create new project. The Project Manager box is also used as a default value for risk properties: recorder, owner, and contact.
- Select the project view that will appear whenever RiskyProject is opened from the Default View list. '***LAST VIEW***' will automatically
load the most recently open RiskyProject session.
- Select or clear the Show or hide startup view check boxes to enable or disable the workflow bar, legends, and splash screens.
- Use Restore Default Column Layout and Set Default Layout to restore and save column sequences and widths for all views.
- In Enable/Disable Views from Workflow Bar by selecting views you wish to Enable or Disable. You can also right click on
Workflow bar to be presented with the same dialog.
All viewing defaults are global, so they are applied to all new projects created on this computer.
