Schedule Diagnostics Based on DCMA 14 Point Assessment
DCMA Point Assessments includes the following tests
DCMA 14 point Schedule Assessment is performed automatically when you click on Schedule Diagnostics >
Start Diagnostics. For some tests, additional settings are required:
- For DCMA-6, DCMA-7, DCMA-12, you may need to enable critical path calculation: in File > Options, go to Calculation tab and select Calculate Critical Path.
- For DCMA-9, you may need to define project status date. File > Options > Calendar tab.
- DCMA-12 can run slow on large schedules. It is possible to enable/disable DCMA-12 test using a checkbox in Welcome to Schedule Diagnostics dialog.
- For DCMA-13, right-click on row ID and click on Milestone for DCMA 13-CPLI and then select milestone which is required for this test.
- You can double-click on each DCMA test and view detailed information about particular metric as part of RiskyProject Help System.
To view Help you must be connected to Internet.
- You can copy test results to clipboard: right-click on row ID and click on Copy.
- You can see issues associated with DCMA tests within list of issues (top list box) by clicking on the particular DCMA test.
See also:
About Schedule Diagnostics
Schedule Diagnostics Configuration
