Modifying Columns in Data Sheets
You can any view by inserting, modifying or hiding columns depending on the type of information you would like to view.
The header can have different background colors, outline colors and text colors.
- Open the Data Sheets and right-click on a column header.
- From the shortcut menu, choose how you want to modify the column:
- Hide
- Insert Column Before or After
- Modify (change field type, field title, title and data alignment, and width). You can also modify header text and color.
Modifying Datasheets
