Mapping custom fields in Microsoft Project to low/high duration/cost/income
fields in RiskyProject
You can use duration or cost fields in Microsoft Project or in any other software
that uses Microsoft Project's XML schema: duration1, duration2, duration3 … to
define low and high duration in RiskyProject. You can also use duration1,
duration2, duration3… fields in Microsoft Project to define low and high
remaining duration for partially completed tasks.
You can use cost1, cost2, cost3, … fields in Microsoft Project to define low,
base, and high cost and income. Text fields are used to save statistical
distribution. If you previously used Risk+, you may map these fields duration
and cost fields the same way as it was done in Risk+. This way you will be able
to migrate data related to uncertainties in Microsoft Project from Risk+ to
RiskyProject. To use these fields, you must map them to the corresponding
fields in before you import the schedule into RiskyProject. This includes if you
are using the RiskyProject toolbar or ribbon in Microsoft Project. To use these fields, you must map them to the corresponding fields in before you
import the schedule into RiskyProject. This includes if you are using the
RiskyProject toolbar or ribbon in Microsoft Project. To map Microsoft Project fields:
- On the RiskyProject Microsoft Project addin click Field Mapping or in
RiskyProject, click File and then choose
Import > Map Microsoft Project Fields….
- Select the Microsoft Project field associated with low/high duration, cost,
and income in RiskyProject.
- Select if you wish to map remaining duration fields as original duration
fields. If remaining duration fields are mapped to the same fields as original
duration fields and percent complete > 0, low and high duration fields in
Microsoft Project are used for low and high remaining duration in RiskyProject.
- If you don’t want to import from Microsoft Project cost data, resources, cost fields, deadlines, and notes,
select appropriate check boxes. It accelerates calculation. This feature is available in version 6.1 and later.
- If you have cost resources, you may wish to convert cost associated with these resources to the fixed cost during import.
You can apply statistical distributions to the fixed cost, but cannot do it with cost resources. If you select check box
Convert cost from cost resources to fixed cost, in RiskyProject cost resource will remain the same as in
Microsoft Project, but cost defined in resource assignments will be equal zero. This feature is available in version 6.1 and later.
- Click OK
Once you define mappings, it will stay in the system registry for all projects
transferred from Microsoft Project to RiskyProject.
- The default mapping in RiskyProject 3.2 or
earlier is different from version 4.2: low duration = duration1, high duration =
duration3, base duration = duration2; duration2 must be equal duration field in
Microsoft Project
- These mappings can be used for other scheduling applications
that use Microsoft Project's XML format, including Oracle's Primavera. Please
note: base fixed cost in Primavera may be saved as Cost1 in XML file.
- If remaining duration fields are mapped to the same as original duration fields
and you changed % complete in Microsoft Project, you must redefine
statistical distribution for duration or update values in duration fields
for Microsoft Project.
RiskyProject for Microsoft Project
Advanced Mapping Microsoft Project
