Managing Risk PropertiesEach risk may have risk properties. These properties are useful for storing any information about the risk. Properties can be use for search and filtering risks in the risk register. Risk properties can be different types:
Integer numbers and real numbers have maximum and minimum values. The list of risk properties is hierarchical; the risk properties are subdivided into separate groups. Editing the default risk properties
Default risk properties are automatically saved in the system registry and can be used for all projects. You may use the Restore Default button to overwrite changes in default risk properties you made with standard set of risk properties. See also |
