DCMA Check #7: Negative FloatThis check calculates percentage of Incomplete Tasks with Negative Float or tasks with Total Slack less than zero. Negative float usually is a result of hard constraints, which should be minimized. Negative float also means that some key date cannot be met. FormulaTargetPercent of incomplete tasks with negative float should not exceed 0% CommentsUsing list of task issues (the list at the top of Diagnostics dialog box) you can find tasks with Negative Float and perform necessary corrections. See also |
