About Risk History
The Risk History records any changes made to the risk over time. The Risk history is updated automatically when you save the project.
Viewing a risk history
  1. On the ribbon, click the Risks tab and then the Risk Register view.
  2. Double-click on a risk ID to open the Risk information dialog box.
  3. Click the History tab to view risk history
  4. To copy a risk history record to the clipboard, right click on a record ID and select Copy Data.
  5. To delete record, right click on record ID and select Delete Item.
  • You can modify the date of the history record. Other fields are read-only, so you cannot modify them, but you can delete the risk history record.
  • Risk history is used to show all changes to the risks over time on the Risk Matrix.
About Risk Attributes
