About Project PreferencesThe Preferences dialog allows individual users to set up preferences for project desktop behaviour and appearance, as well as setting up default export and 3rd party settings:
You may define the path for the external applications in the Tools tab. This is useful if you have removed an external application or a new release of the external application is installed and RiskyProject cannot find it in the registry. You can also use the Tool tab to correct a path if you selected the wrong file for external application. Click on Envision Database Connection Settings to configure integration with the Proteus Envision® database. This can be done the same way as configuration for connecting with RiskyProject database, as outlined in the RiskyProject Enterprise Administrator’s Guide. To define a path to an external application: See also |
