Renaming a calendar
You can rename calendars that you have created.
- Click the Schedule tab. In the Schedule and Calendars group, click Working Time.
- Select the calendar that you want to rename from the Calendar drop-down list.
- Click the Rename button. The Rename Calendar dialog box opens.
- Type in a new calendar name.
- Type in a note for this calendar (optional).
- Click OK.
When you use any calendar other than the Standard, ensure that you properly translate the duration through the project. To define hours per day,
hours per week, and days per month go to Options and select Calendar tab.
Creating a New Calendar
