Modifying ProjectsTo modify a project schedule, you must open it. If the project has risks and uncertainties, they will be reflected in the project portfolio as soon the project is saved. In particular, risk scores will be re-calculated and the Project Gantt chart will be updated. Project names and project priorities can be updated without opening the project. You may be required to modify the project start time. To modify a project start time:
See also |
