Import an XML File
Importing xml files allows you to import supported xml project files (Microsoft
Project xml schema) into your database and portfolio. The xml file import
procedure is the same as Import a file, but as MS Project xml does not support
risks and mitigation plans, this step is omitted.
To import an xml file:
- Click the Projects tab. In the Project Views
group, click any Project view.
- Select the row in which you would like to place the project.
- In the Export/Import group, click the Import from XML
button. The Open dialog box opens.
- Navigate to the file (*.xml) and click Open.
- Select the hierarchy location where you want to place the project. You can
rename the project if required in the Project Name box.
Creating a Portfolio Hierarchy
Import RiskyProject (*.alm) file
