Deleting Risk AssignmentsRisks can be deleted using the same process as in the standalone RiskyProject (see Deleting Risks from Risk Register). You may:
All risk assignments will also be deleted. If these risks are assigned to the projects you need to open projects individually, recalculate them, and save them. This will allow the project risk score and other information related to project uncertainties to be updated. See also |
