About User Logon HistoryIn RiskyProject Enterprise you can view User Logon History. The Logon History allows the Administrator to view the entire logon history of all the users. The history includes:
To access logon history:
Delete all open sessionsAs an administrator, you can remove logon sessions that are currently open from the list. This can be useful if the user “killed” the application without properly exiting it. If you use the concurrent user licensing model, it would limit the number of concurrent sessions and users may not be able to logon to RiskyProject. To delete open sessions, click Delete all open sessions. Set the number of months logon records are kept.Depending on the number of users you have, you may want to keep the history at a manageable size. To set this period, type in the number of months in the months box and click OK. Delete sessions from the list:
See also |
