About Risk Visibility and Risk AssignmentEach risk can be visible and assigned to specific projects. Visibility and assignment are not identical: When you create a new risk, it will inherit the default visibility settings. Default visibility is defined in Portfolio Options. See Risk Visibility (Approval) Rules for more information. Default visibility can be set for:
See also |
