About Project Preferences
The Preferences dialog allows individual users to set up preferences for project desktop behaviour and appearance, as well as
setting up default export and 3rd party settings:
- Select the project view that will appear whenever RiskyProject is opened
from the Default View list. “***LAST VIEW***” will
automatically load the most recently open RiskyProject session.
- Select or clear the Show or hide startup view check boxes to enable or
disable the workflow bar, legends, and splash screens.
- Select the data type option that you want to use when you export project
data to 3rd party tools or to MPX file. Each time you are exporting data to MPX
file or launching external software rather than Microsoft Project you will be
given two options:
- export current project schedule
- export results of
probabilistic analysis
You can setup a default selection of these options or you disable the dialog
which comes up before you export a file. You can define the path for the
external applications in the Tools tab. This is useful if you have removed an
external application or a new release of the external application is installed
and RiskyProject cannot find it in the registry. You can also use the Tool tab
to correct a path if you selected the wrong file for external application.
To
define a path to an external application:
- Click the Projects tab. In the
Settings group, click Preferences.
- Click the Browse button to browse for the
application executable and enter in the URL of the application vendor
- Click
OK to save the preferences.
About Portfolio Options
Portfolio Options and Peferences vs. Project Options
