RiskyProject Data Sheets
All RiskyProject views, except for the Project Summary view and
Project Dashboard, contain data sheets. Data sheets are used to
enter and present data in a grid format. Grids are also used in some
dialog boxes. All data sheets have similar features.
Data sheets are used to display task information, resources, risks,
and results of sensitivity analysis. Data sheets are composed of
columns and rows. Each column has specific properties, which
represent a specific data type. For example, resource name, resource
type, etc. You can customize data sheets to display the columns in
any order and any with a title in the column header. See the
appendix for a full description of each field.
Modifying data sheets
You can modify all of the RiskyProject views by inserting,
modifying, or hiding columns depending on the type of information
that you want to view.
- Right-click on the column header.
- From the shortcut menu, choose how you want to modify the column
- Hide
- Insert Column Before or After
- Modify: Change field type, Title, Title and Data alignment, Width
- Save Column Layout: current column layout will be saved in the registry for all new projects
- This adjustment will be saved in RiskyProject data file
associated with the particular project. Therefore, the next time you
open the project, you will see your column modifications. This way
you can create a customized data sheets for each view.
- Remember that these adjustments to data sheets are inclusive
to each view. For example, if you inserted column into the Gantt
View, it will not be reflected in Result Gantt View.
- You cannot hide or modify IDs.
- In the Risk Register view, you can extend the height of rows, add headers that span multiple columns above regular columns and adjust
the width of columns based on maximum width of information contained.
Copying, cutting and pasting selected
rows
You can copy, cut, and paste selected items in each
data sheet except for the results of sensitivity analysis.
- Select one or multiple rows in a data sheet.
- From the Clipboard group, choose Cut or Copy.
- Open the data sheet in which you want to paste the data.
- Select the row in which you want to paste the data.
- The maximum number of rows in RiskyProject is 20,000. You cannot paste items beyond this limit. However, if you import
a project from other project management software, the maximum number of tasks will be increased so it can accommodate all
tasks in the original project schedule.
- You can paste data only to compatible data sheets (e.g. tasks can be pasted to the data sheets containing tasks, and risks
can be pasted to data sheets containing risks).
- You cannot paste data copied or cut from another document with the exception of risks.
Inserting and deleting items
You can delete and insert items for each data sheet except for
results of sensitivity analysis. Any data that can be entered into
the data sheet rows. The quickest to insert or delete items is to
use the Insert and Delete buttons located on the Format toolbar.
- Select an item or multiple items. New items will be inserted
above upper selected item. The number of items to be inserted equals
the number items you have selected.
- From the Format toolbar, click the Insert Item button.
Saving column layout
After you modify a column layout, you can save it in the system registry for all new projects created on your computer. You save a
column layout by following these steps:
- Go to Options
- Go to View tab
- Click on Set Default Column Layout to set column layout for all new projects
- You can restore the predefined layout of columns for all views by clicking on Restore Default Column Layout
Alternatively, you can right-click on any column and click Save Column Layout from the drop-down menu.
This layout will be applied to the current project.
Reports Setting up Reports
