Importing data from other project management softwareYou can import existing project schedules from Microsoft Project, Primavera and other project management tools using a variety of file formats. Importing Microsoft Project filesYou can import MS Project files using XML format.
You can use the RiskyProject toolbar or ribbon in Microsoft Project to transfer your schedule from Microsoft Project to RiskyProject. When you use the RiskyProject toolbar or ribbon, your schedule in Microsoft Project will be associated with risks and uncertainties defined in RiskyProject. Please read RiskyProject for Microsoft Project for more information. Importing data from other project management softwareRiskyProject can import data from other project management software in Microsoft Project XML file, as well Oracle Primavera XER file formats.
Due to the specific features of each application and the probabilistic nature of RiskyProject data, in very rare cases there may be discrepancies between the original project schedule and the imported schedule in RiskyProject. Importing data from other project management software and retaining risk assignments:Sometimes you may want to import a project schedule from Microsoft Project or other software and retain existing risk assignments. It can be useful when you have imported a project schedule from Microsoft Project or other software, assigned risks in RiskyProject, and then updated the project schedule in Microsoft Project.
Importing risks and uncertainties from different RiskyProject file:You can import risks and uncertainties from a different RiskyProject file and assign them to tasks and resources in the current schedule.
If the schedule originated in Microsoft Project, the risks will be assigned to the correct task and resource using the unique ID. Unique IDs do not change when you insert or delete tasks. If you created the schedule in the RiskyProject the risk will be assigned based to the tasks or resources based on ID shown in the task or resource data sheets. Such ID changes when you insert or delete tasks. See alsoExporting Projects |
and then Open. The Open File dialog
box opens.
