			Adding custom risk propertiesRisk properties are attributes that can be used for filtering or searching. While some properties are populated automatically (e.g. Creation Date), you can enter specific values as required. You define default risk properties in the Default Risk Properties dialog box accessible from the Risk menu.
 Risk properties do not affect calculations, including risk ranking, cost, duration, etc. For example, the risk property "Potential Loss in Monetary Terms" does not affect cost calculations. See also  |
