Revenue Report View
The Revenue Report includes all of the input and result data associated with cost, income, and revenue for all tasks in the Schedule. Use the Revenue Report view to view input data and results associated with cost, income, and revenue. Revenue report show low, base, and high cost, income, and revenue for all tasks.
Default fields
  • Tasks Name: Name of the task.
  • Total Cost: Cost associated with resources assigned to the particular task plus fixed task cost. Calculated based on current schedule duration and fixed cost.
  • Income: Total income as a result of probabilistic calculation. Will have no value in the current schedule calculation.
  • Revenue: Revenue = Income - Cost on each iteration. If Income is zero for all tasks, revenue is not calculated. Mean Revenue is calculated as result of statistical analysis. Will have no value in the current schedule calculation.
  • Cost Actual: Actual Cost can be calculated automatically (default) using tracking data. You can manually input actual cost, if you uncheck flag in Options dialog (cost view). Actual cash flow diagram will be displayed within Cost Analysis view.
  • Cost Low: Total low cost (fixed task cost plus variable cost, e.g. associated with resource) as a result of probabilistic calculation. Will have no value in the current schedule calculation. Can be minimum, P1, P5, P10.
  • Cost: Mean Total Cost as a result of probabilistic calculation. Will have no value in the current schedule calculation.
  •  Cost High: Total high cost (fixed task cost plus variable cost, e.g. associated with resource) as a result of probabilistic calculation. Will have no value in the current schedule calculation. Can be maximum, P90, P95, P99.
  • Income Actual: Actual: Income that is accrued during the course of a task or project. RiskyProject calculate actual cost automatically based on tracking data. Alternatively, you can enter this income manually if you uncheck a flag in Options (cost tab)
  • Income Low: Total low income as a result of probabilistic calculation. Will have no value in the current schedule calculation. Can be minimum, P1, P5, P10.
  • Income High: Total high income as a result of probabilistic calculation. Will have no value in the current schedule calculation. Can be maximum, P90, P95, P99.
  • Revenue Low: Revenue = Income - Cost on each iteration. If Income is zero for all tasks, revenue is not calculated. Low Revenue is calculated as result of statistical analysis. Will have no value in the current schedule calculation. Can be minimum, P1, P5, P10.
  • Revenue High: Revenue = Income - Cost on each iteration. If Income is zero for all tasks, revenue is not calculated. Low Revenue is calculated as result of statistical analysis. Will have no value in the current schedule calculation. Can be maximum, P90, P95, P99.
  • Res. Cost: Cost associated with all resources assigned to the particular task. Calculated during deterministic current schedule calculation. Resource cost for summary tasks is calculation as cost of all resources assigned to summary task plus resource cost of all subtask.
Setting up reports for printing
See Setting up Reports
Printing reports
Click File and choose Print.
Previewing reports
Click File and choose Print Preview.
