GlossaryLocal Risk AssignmentA stochastic event, which is assigned a particular task or resource. Local risks are added using the Task Information dialog box for tasks or the Resource Information dialog box for resources. You can also use Risk Drag'n'Drop View to define local risks for tasks and resources. The Local Risks dialog box can be opened from the shortcut menu in any views with tasks. You may also perform assignment of local risk from Risk Assignment view. |
