GlossaryCumulative Probability PlotThis chart plots cumulative probability versus the value of a variable. A cumulative probability chart allows you to analyze the risk associated with a variable. All cumulative probability charts in RiskyProject are interactive. By moving the slider, you can determine what is the chance that the project will be completed within a given period; or, what is the chance that the cost of the project will be within budget? Cumulative probability charts can be combined with frequency charts using the same variable. |
