Description |
You can select the statistical
distribution for the duration to be used
in the probabilistic
calculations.
Distribution can be Undefined, Normal, Lognormal, Uniform,
and Triangular. Undefined distribution means that Low Duration and High Duration is
ignored, and duration is Base in all iterations.
If low,
base, and high default durations are the same,
distribution is set to Undefined. In other cases, default
distribution is Triangular. For more information, see
"How to
define distribution for Start Time, Cost, Income, and Duration".
