|  | Description | Base Start Time is used to calculate
                  current project schedule. It also used to calculate start time
                  of each iteration of the probabilistic calculation.  Note that
                  in most cases, the Start Time is calculated automatically
                  based on predecessor's finish time and lag. If a task does not
                  have predecessors, the default start time is the current time
                  or default start time from options (see "RiskyProject
                  calculation and display options"). If you update the Start
                  Time, the Constraint is set to "Must
                  Start On".
                  See "Start, Finish Times, and Constraints" for more details.  |  |
