Duration low- result
Type of the field
Static Text
Low Dur
Description
Low duration as a result of probabilistic calculations. It is blank for current schedule calculations. Can be minimum, P1, P5, P10. It is defined in Options (Calculation tab).
Related Fields
Duration Base- result Duration High- result
