Name of parameters (shown on the tool tip) |
Seed
for time |
Type of the field |
Edit box with
spin
control |
Short name (shown in the
header) |
Seed,time
Description |
Seed is starting parameter
for random number generation used to
calculate time when
risk
will
occur. If you have two
risks that should occur at the same time
for
the particular task,
you
can
make their seeds the same. |
Related
Fields |
Seed
for
outcome
