| Description |
                  If this check box is selected, the risk is used in the
					calculation. If you enable summary risks, all sub risks are
					enabled. In addition, vice verse, if you disable
                  summary risk all sub risks are disabled. If at least one sub
                  risk is enabled, summary risk is
                  enabled. |  |
