| Name of parameters (shown on the tool tip) |
                    Finish time
                  of the
                  risk occurrence |  |
              | Type of the field |
                   Edit Box with Spin
                   Control |  |
              | Short name (shown in the
                header) |
                  Finish |  |
              | Description |
                           Risk cannot occur
                           after
                           this
                  time. Time is defined as a percent of
                         total        task duration. For example, task duration is5 days. Finish
                  time of risk occurrence 80% means that risk will occur before
                  the end of fourth day.
              | Related
                Fields |
                  Moment of RiskDistribuition chart
 Most likely
                  time of the risk occurrence
 Start time of the risk
                  occurrence
